Ok i looked in the how to section and couldnt find the answer so i figured one of you guy's have done this before so i need to know how to change the grips on a 06 street glide.
Thanks Daniel
It's really quite simple. If you have the service manual, it's step by step. The only part you have to be careful is to make sure that you count the threads on each throttle cable so you can set them back to where they were before you started. Put the throttle grip on first so you can match the postion of the left grip to where the throttle grip is. You don't want them not matched up because it will definately show.
