Touring Bike Brake Upgrades
I noticed on a Trike model that they had what looked like a 6 piston calibers on them. A search of it's specs shows that they are indeed 6 pistons. Does anyone know if they would bolt up to a FLH front forks ?
Front: 6-piston fixed front with (4) 31.75 mm front pistons and (2) 25.4 mm linked rear pistons
Rear: 31.75 mm 1-piston floating
Parking: Foot actuated dual parking brake
Those calipers actually have 2 separate brake line to each caliper. The 2 center pistons are connected to the REAR master cylinder and the remaining 4 pistons are connected to the FRONT master cylinder. I don't know if they would bolt up but you would need to come up with a way of activating all 6 pistons.
My understanding is that a pair of the front pistons are linked with the rear, operating together, while the other pistons are indeed operated by the front brake. I also have looked at them to use as front only calipers, but passed that idea over.
As for 6-pistons or not I have been using a pair with 13" floating rotors for many years - when working well they are fine - you just can't have too much of a good thing! Control is all......
