Gauge wiring for lighting
Old 05-06-2015 | 09:46 PM
Cull22420's Avatar
Cull22420
Default Gauge wiring for lighting
Can anyone recommend wiring gauge for wiring lights. I'm converting to all LED and adding some different under lighting. Just looking for any recommendations. Thanks guys
Old 05-06-2015 | 10:21 PM
N-Truder's Avatar
N-Truder
LED's don't pull the amps that incandescents do so factory wiring ought to be fine. If I was guessing, probably 18 gauge.
Old 05-07-2015 | 12:01 PM
HD-Gyro's Avatar
HD-Gyro
Default LED wiring
18 ga is more than enough, you could certainly use thinner to meet the electrical demand. Most of the reason to use heavier wire than required is to withstand the abuse of the vibrations and the occasional tug when adjusting something else and you pull that wire by accident.
AllenW
04-16-2016 11:12 AM
legoiii
Audio Systems
03-30-2016 06:14 AM
Silvio
02-13-2014 08:46 PM
Jarhead8692
Electrical/Lighting/Alarm
07-18-2010 07:32 PM
hogster1961
01-25-2008 07:25 PM
Quick Reply: Gauge wiring for lighting
