Stock Oil Pressure Gauge Reading
I'm asking this strictly out of curiousity. AFTER getting up to full operating temperature, where does your stock oil pressure guage read? Mine settles in just a tickpast the 32 psi reading, which on my '06 Ultra is at TDC. When I pull off and come to a full stop but still idling, it drops to about halfway between zero and 32 psi.
ORIGINAL: gunrunner
Hold onto your hat after stoping and at idle when it gets hot. It will drop to 5psi on the gauge and it looks like its on zero, but its normal.
I figured it was normal for it to drop that much at idle (when hot), but I guess that I really never paid that much attention. After changing mylubes last night to synthetics, I was paying particular attention to the gauge today and wanted tofind outwhat others were seeing. Sounds like I'm running pretty much at 'par.'
ORIGINAL: RanD
The pressure relates to temperature, so if you have an oil-temp gauge you can watch one go up, and the other goes down, and versie vicie.
ORIGINAL: gunrunner
With our Arizona summers, I look for it to stay low when it's reeeal hot [:@]
