Stock pump 36 to38 cold high idle ,12 when hot idle, 32 hot running. fueling pump 38 cold idle ,40 running cool, 34 to 36 running hot, 30 to32 hot idle. all with amsoil..
The only parts that require oil pressure on the HD engine are the lifters, and going down to almost zero is normal when hot.
I believe the piston jets also require pressure. Just being picky. My oil pressure likes to hover around 30-34 psi at 60 mph with RedLine synthetic 20w-50. When really hot, it drops to around 8 psi at idle. Highest oil temp I have seen this season so far is 180 Deg F with an outside temp of 81 deg F.
