What aryou guys doing for antenna on extended fender
I took the idea of the video in here but didnr like the way it left so much cable and no where to really tie anything off to. So what i did wth your seat off up close to the tank you will see a tab there on the left (shifter) side. That will lead up into the tank tunnel. I cut about 1/3 of my antenna off probly not necessary but i did it anyways. Slide the antenna up into the tunnel and zip tie everything up. Reception is pretty good i havent noticed any difference. The only difference i have is my load equalizer is mounted fairly close (on top of the ecm) and when using the turn signal it gets fuzzy with the blinker.
