clutch issue??
clutch issue??
I don't really the answer since this is my first Harley, maybe normal. I adjusted my clutch at 10,000 miles. Turned the screw out just past 1/2 turn at clutch pack. Cable adjusted with about a 1/8th of play. It has felt like its not catching right lately. So I adjusted it yesterday with engine cold. Found I had to turn the adjuster screw 1.5 turns in to were it just stops. I didn't crank on it. How has it wore so much in 5,000 miles. I followed the service manual adjusting it. Is this normal?
I took slack all the way out of cable, broke jamnut loose on set screw, turn set screw in until it just stops, back off just a past half turn, tighten jamnut to 120inlbs. adjust cable to 1/8in. play at lever. Is there anything I missed?
drspencer
06-04-2011 03:25 PM
