What's the most amount of gas you put in?
Old 05-03-2015 | 11:18 AM
FinalShot's Avatar
FinalShot
Old 05-03-2015 | 11:42 AM
DresserDude's Avatar
DresserDude
Originally Posted by Buelligan666
5.89 gal. This thread is gonna get everyone yelled at, because the fuel cools the fuel pump and if you don't keep at least blah blah blah blah...........
I ran my 06 Road King out of gas, spitting and sputtering for about 1/2 mile. Filled up full at 5.21 gallons. On my way home, 165 miles, it was backfiring, farting, burping and wouldn't go over 70-75 miles. When I started the bike the next day, the fuel pump didn't sound right. Took off the canopy and the fuel pressure regulator bowl's dog ears had broken and it was sucking air bad. Fuel pump was fine, but the plastic bowl gave out.
Old 05-03-2015 | 11:55 AM
screamn_eagle's Avatar
screamn_eagle
my son and i were out on my 2 bikes and we got detoured with very little gas. he was on my 04 cvo (5 gallon tank). when we finally got to a gas station we got 5.12 gallons in that bad boy. it never stalled.
Old 05-03-2015 | 11:56 AM
FinalShot's Avatar
FinalShot
Yep and has happened in a couple of the other threads. I have yet to have any proof shown to me and I've asked every time it gets brought up. If it was truly the case, we'd be seeing fuel pump threads here like oil, tuner, exhaust..... questions. And, I'll add that it is the fuel that is ran internally through the pump that aides in the cooling, not sitting in a bath of gas.
I bet that if you ran your tank totally out of gas and continued to run the fuel pump, it'd burn up. That is, if you could find a way to do that. I always ride full to empty.
Old 05-03-2015 | 11:58 AM
mkguitar's Avatar
mkguitar
Just for those who may not be aware
the gas in the tank cools the pump- best practice to run 1/4 tank or more as much as possible- better cooling, pump lasts longer.
we all get into situations where we are pressing it...but when you have a choice run higher levels.
same for any fuel pump in the tank...most efi cars and trucks
mike
Old 05-03-2015 | 02:07 PM
DRAM40A1's Avatar
DRAM40A1
6th Gear
I've only fueled my road glide once. It took 2.9 gallons....
Old 05-03-2015 | 02:45 PM
From_Behind's Avatar
From_Behind
Veteran: Marine Corp
Default What's the most amount of gas you put in?
About 5.6 in a 6 gallon tank, on I-90, heading to Sturgis.
The more important question is where you set your fuel cap while filling a tank that low!
Old 05-03-2015 | 05:41 PM
OldPhat's Avatar
OldPhat
230 miles, & added 5.4 gallons, dash said 26 miles until empty.
Old 05-03-2015 | 07:02 PM
SouthpawHD's Avatar
SouthpawHD
Pretty sure you're supposed to exchange it for the Screamin Eagle one with each fill up.
Old 05-03-2015 | 08:41 PM
Tactical111's Avatar
Tactical111
Thumbs up
Was thinking the same thing but sometimes running real low can't be avoided. Oh for the days of my old Evo with no fuel pump!
Quick Reply: What's the most amount of gas you put in?
