Stupid question from a non-mechanic
Old 04-30-2015 | 02:22 PM
Swamphunter's Avatar
Swamphunter
Ok thanks guys. I'm afraid if I put it out of sight too much, I'll be less likely tu plug it in when I'm going to be parked for more than a few days.
Old 04-30-2015 | 02:37 PM
RKZen's Avatar
RKZen
Yup, looks like a good place to me.
Old 04-30-2015 | 08:51 PM
Pitbull2411's Avatar
Pitbull2411
That's the exactly where I have mine zip tied too.
Old 04-30-2015 | 09:57 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
I routed mine through the hole in the frame support behind the motor and above the transmission between the rear down tubes. You can't see it unless your looking for it. It only sticks out about 2 or 3 inches. It's out of the way and readily available to plug it in any time.
Old 05-01-2015 | 05:00 AM
just plain john's Avatar
just plain john
My bike (05) has a hole in the plate just ahead of the battery on the clutch side. I simply push the connector back in there, it's easy to pull out and can't be seen when stowed.
Old 05-01-2015 | 08:12 AM
Farmboy666's Avatar
Farmboy666
Mine is zipped and just sticks out a little in front part of left side cover, I use it to plug GPS in on longer trips. You could just take the cap off, run it arond the wire and put cap back on.
Old 05-01-2015 | 06:06 PM
Veekness's Avatar
Veekness
Don't overthink it...mine bounces around in that general area...I tied it off enuf to keep it away from the exhaust. Good to go.
Old 05-01-2015 | 06:17 PM
louie2323's Avatar
louie2323
Stage I
This is where I put mine as well. Easy access and never even notice it's there.
ORradtech
Electrical/Lighting/Alarm
04-19-2016 07:15 AM
donutsrd
01-15-2016 08:14 AM
merriganc
10-17-2014 12:17 PM
7Sixpack7
04-23-2012 07:38 PM
Nicky Pass
10-27-2010 05:23 PM
Quick Reply: Stupid question from a non-mechanic
