Stripped Axle Nut Clamp Bolt
I was changing out my tires yesterday on my 2014 road king and I stripped my axle nut clamp bolt. It's an allen head bolt and it's sunk into the clamp so it doesn't stick out so I can't grab it with anything and twist.
It'll probably be another 6 months to a year before it needs to come off again so I have time to plan. What are some of my options? I've never done this before so I'm trying to find the easiest way. I assume I'll have to drill it?
If it is just mildly rounded out you can get some "Anti cam out fluid", Kimball-Midwest sells it, Ive even seen it at a Sears once. The stuff is a miracle, it increases the torque grip by 400%. Ive used it on screws, allens, and torx. If its beyond that tap in a torx with that fluid and it should come out, maybe use a hand impact wrench. Snap on makes the strongest torx bits, better than Mac, Matco, Crapsman, proto. I see wrenches in my shop constantly exchanging bits, Snap on last the longest without breaking.
