questions about inspection write ups 91' flhs
Hi - purchasing a 1991 FLHS electra Glide,
there were two things that the inspection station hit it up for.
1. the fog lights stay on with the hi beams. ( is that no normal)
2. no brake light from the front brake handle ( my cousin has a newer soft tail and there's no brake switch on his front brake)..
I was just wondering if these were real defects or was the inspection station being a pain in the &*#!
OH and no side reflectors
This is a Maryland Inspection
RE: questions about inspection write ups 91' flhs
The fog light thing is a common mod...check out http://www.moccsplace.com/images/harley/plw.gif
The front brake lever does make contact with a switch behind the lever...if it isn't just adjust and you should be fine.
The reflector issue does seem a bit much though....
