Front rotor replacement questions?
Since HD won't replace my warped rotors under the ESP I picked up a couple of rotors cheap from a friend that replaced his wheels and rotors with after market.
I've got several questions. There is some light surface rust on them. Do I need to sand it off, or just let the brake pad do it? If I should sand them, what grit paper would be best? And lastly, are the rotor bolts single use, or can I reuse them?
Thanks
David
Thanks
David
Harley says that rotor bolts are a one use item. The new ones come with some kind of thread locker on them already. I personally hate the Torx heads on them and would replace them with Stainless socket head caps, but that's just me! By the end of this year I'll be retired and living near Hallsville...just down the road from you.
David
I was down there when it went through. We went and scoped out the damage, mostly trees close by my fiancée's house. The bigger damage was in Longview.
NAND
09-23-2008 10:27 PM
