RKC cruise control not working
The cruise hasn't worked on my 2006 for quite some time and I've finally decided to check it out. The only thing that I can find wrong is a very small 'tab' within the front brake lever that looks like it has broken.
Anyone know (1) what it is, (2) could this cause the cruise to fail to engage and (3) how to replace it?
Thanks.
Thanks.
Fuse !. Had the same problem with my '06 RKC. Young Mechanic messed up thinking it was the switch. Took it off and soldiered twice to no avail. The other mechanic came over and asked this guy, "Have you checked the fuse yet ?." He went oops and checked. Found it was the fuse !. Always start something small before going BIG.
Thorey
Thorey
Yep, that's where I'd put my money. On the right side of the goose neck, just need to unplug one lead. The CC won't disengage when you roll off the throttle, but I found that to be a PIA anyways. Cheapest repair you'll ever make!
