When I bought this limited he had it slammed to fit his short legs. I just like the rear shocks bottoming out. Have adj through the whole shock and still not satisfied. Thinking about going back with the original air shock.
Bottoming is two functions, spring rate and damping. Many focus only on the spring rate, and ignore the damping. Unfortunately, many shock makers ensure that is your only choice, by sealing the hydraulics. With the original shock, you can adjust the damping rate as well as the spring rate via a fluid change.
