Why Won't My Ultra Limited Start?
Hi guys!
After a long winter's sleep I dropped a new fully charged battery into my 2010 FLHTK today. All battery connections are good. I turn the ignition and all my panel lights came on...so far it's all good. Then I hit the starter and all I hear is "click, click, click..."
I decided at the end of last season to get a new battery this spring because on one occasion late last fall after the bike sat for a good 10 minutes with the 4-ways on and motor off, it wouldn't start. I boosted it from a guy's lawn tractor. Rode the bike home and turned it off, then started it back up no problem. But I decided that come spring I'd get the new battery. I left the old battery in the bike over the winter until today when I swapped in the new one. Now it's just "click, click, click..."
What do you think?
Thanks.
Dave
What do you think?
Thanks.
Dave
My guess is that you have a bad new battery, possibly with a bridged set of cells.
If you have a voltmeter, check the resting DC voltage--new and fully charged batteries should read well over 12 volts at rest. Something like 12.5-12.8.
Then, while the meter is still attached, hit the starter. If the voltage drops way down past 9-10 DC volts, there's your problem.
It's been known to happen...
Good luck!
Shane
Good luck!
Shane
