Roadside Flat Tire Repair - Kit / Tools / Advice
I use the same pump along with a Dynaplug Pro Aluminum Tire repair kit. I haven't had to use the Dynaplug kit yet, so I can't comment on it's actual performance, but the product looks to be well made and it's certainly small and packs easily. The best price I've seen on the Dynaplug kit is from a vendor (Motopumps) that posts of the ADV forum. You probably should verify if the prices are current. My Dynaplug Pro Aluminum was $47.99. Sure, it's a bit expensive, but just like in the backpacking world, you pay more for something that's light and packs smaller.
http://www.advrider.com/forums/showp...&postcount=469
I have this compressor. I managed to stick a T-handle plug kit in the case it comes with. Doesn't take up too much room in the saddlebag. Haven't had to use it on the bike yet, but have had to use it on the cars a couple of times. It fills slow but works well.
If you carry the old style (string) plug kit, I'd suggest testing it out by drilling or punching a small hole in a tire, preferably on the rim and aired up then trying to put a plug in. It's NOT always easy on a bike tire. Wear a glove as well. The last time I plugged a tire, half of the T handle broke off gashing my hand.
My apologies if these are some dumb questions but I would like and appreciate the benefit of your good experience:
What kit / tools etc. do you carry with your machine to deal with a flat tire on a journey?
Have you experienced a flat; say in the middle of nowhere and were you able to fix it enough to get to where the tire could be properly repaired / replaced? In other words did the tools / kit you packed actually bail you out?
You want a kit that will be easy to use and one that vulcanizes the repair strings to the tire carcass.
Personally, I use a tire repair kit made by BestRest. It uses the same strings and vulcanizing glue that is used to repair tires on semi-trucks. If it'll repair those tires, it'll work on a HD, or in my case a BMW K11LT.
http://www.bestrestproducts.com/p-23...epair-kit.aspx
I have tubeless tires - I carry the Stop and Go Tubeless Puncture Pilot kit. Very compact, does not consume much room in my saddlebag. This includes plugs and a mini compressor. I have not used this yet, although I've plugged both my car and previous motorcycle tires at home in the past, so I would be comfortable using this on the road. I also have a CAA Plus membership... https://www.denniskirk.com/stop-and-...prd/283536.sku
Mine have tubes now so am a hog member so will cover my tow. When I had my sporty carried a plug kit and slime tire electric pump. Used it once on my bike and several times on others. My tire that I plugged was new and only had 500 miles on it. Rode it till it wore out and replaced it then.
Edit: I see someone beat me to it. The Dennis Kirk package is cheaper than buying them separate.
Best to go tube less and that's what I did with wife's 08 spoke wheeled UC once friend's wife had a flat with tube in middle of no where no cell and closest city was in different state and towing co. won't cross state due to toll line, long story short 8 hrs ride turned out be 17 hrs.Had compressor, plugs and whole shebang on my bike and it was use less on that bike.
