New Metz on Rear Only?
Old 04-23-2007, 10:41 PM
RanD's Avatar
RanD
RanD is offline
Default New Metz on Rear Only?
I was in to see my local Indy today regarding a new rear tire. My current tire has about 8K miles on it and next month I'm heading out on a 3500 mile ride. I've pretty much decided to start the trip out on a new skin so that I don't need to have it done on the road. My Indy says that with the Metz I can do just the rear and don't have to worry about changing out the front (its an OEM Dunlop). He says that with other tires (like Continentals, for example) you shouldn't do it, but that the Metz rear and Dunlop front are compatible. What say you?
Old 04-23-2007, 10:46 PM
huffhuff's Avatar
huffhuff
huffhuff is offline
Default RE: New Metz on Rear Only?
not perfection but i've had avon on rear and dunlop up front. take your time to get used to the handling after tire installation.
Old 04-23-2007, 10:50 PM
thumper05's Avatar
thumper05
thumper05 is offline
no issues here with 2300miles on a metz me880 rear and lop front
Old 04-23-2007, 10:52 PM
anubisss's Avatar
anubisss
anubisss is offline
I would change both. I don't like mixing brands unless it is a question of money. I put the metzers on my fatboy after having dunlops a while ago and the handling is so much better...
Old 04-23-2007, 11:01 PM
RanD's Avatar
RanD
RanD is offline
Thanks folks. I guess I'd spend the money for both if it were necessary, but I'm not into wasting a perfectly good front tire if I don't need to.
Old 04-23-2007, 11:17 PM
UGGA's Avatar
UGGA
UGGA is offline
I'm in the same situation as you. I'm leaving on a 4000+ mile ride in 2 weeks and my rear tire won't make it but my front will. I'm taking my Gold Wing instead of the Street Glide, and Gold Wing tires are very large and expensive! I just put on a new Dunlop Elite 3 in the rear, and I kept my Metz ME880 in front since it has a lot of life still left. The bike handles just fine with the combo. The tread pattern and roll angle of the two tires is very similar. You should be just fine.
Doug
Old 04-23-2007, 11:24 PM
RanD's Avatar
RanD
RanD is offline
Thanks Doug. I'm thinking that I'll get the rear put on in the next week or two and see how it feels. If it feels weird, I'll have the front changed out too, but from what I'm hearing it won't be an issue.
Old 04-23-2007, 11:27 PM
Bigredone's Avatar
Bigredone
Bigredone is offline
I wanted to go with Metz but my front tire still has 50% tread depth, so I replaced the rear with a Dunlop. We don't mix tires on patrol cars due to handling issuesand I'm definately not mixing tires on my bike.
Just my .02 worth
Old 04-24-2007, 02:13 AM
FLWanderer's Avatar
FLWanderer
FLWanderer is offline
I just chged out the rear on my EGC with ME880 and still have Dunlop on front....put 3,000 mi
on it so far and did not notice any problems. I think you'll do fine with that combination. Will
be doing a 6,000 mi trip this summer with that setup.
I've heard that the Metz are alittle softer tire...which provides better grip than the lop's. Not sure
if I'll get the mileage out of it that I got with the D402....but we'll see.
Old 04-24-2007, 10:11 AM
HogBack's Avatar
HogBack
HogBack is offline
RanD.... replace front and back with the same type/brand for best handing... and for peace of mind replace tires in a set...
Quick Reply: New Metz on Rear Only?
