Headlamp issue
Headlamp issue
I've got an 07 ultra, and i started it up last night and the headlamp and driving lights were off. Pulled the headlamp fuse and it was blown. Replaced it, turned it on, blew this fuse. Where should I start to look first? Turn signals, brake lights and tour pack lights are fully functional. Only front lighting out.. Any thoughts or suggestions are appreciated.
Not to be an ***, but that's why they sell service manuals. I have one out in the shop, I'll check it. My guess is that the headlight is fused separately from the rest, and the wire is pinched or chafed somewhere and is going to ground. Unplug the headlight and see if it still blows the fuse.
as above it may be a chafed wire in the fairing...some riders have had broken fairing mounts which chew the wiring.
some remove the left side hand controls and pinch wires in the housing
suggest you open up the fairing and inspect the wiring...but first ( spots switched off) pull the bulb and start testing there.
if the inside of the fuse looks carbon arced, black soot or spattered, that is a short circuit ( wiring).
If the fuse material looks to have simply sagged and parted, that is an overload.
could be bulb, bad light socket ( using extra high watt bulbs?) or wiring
( or the bike is jealous of the remodeling attention the house is getting)
mike
mike
as above it may be a chafed wire in the fairing...some riders have had broken fairing mounts which chew the wiring. some remove the left side hand controls and pinch wires in the housing suggest you open up the fairing and inspect the wiring...but first ( spots switched off) pull the bulb and start testing there. if the inside of the fuse looks carbon arced, black soot or spattered, that is a short circuit ( wiring). If the fuse material looks to have simply sagged and parted, that is an overload. could be bulb, bad light socket ( using extra high watt bulbs?) or wiring ( or the bike is jealous of the remodeling attention the house is getting) mike
Plus 1 on that!!! Ever make it to Mass. Ring me up....always great posts!
Well, I beleive it was a pinched wire in the control housing. I put chrome switches on her this winter. I was wondering if a pinched wire was the culprit there after reading everyone's posts. I took the housing apart, stretched the wires out and it performed perfectly. One more coat of paint on kitchen walls and hopefully I can spoil the bike by installing bars, windshield and tour pack relocation kit. Buddy gave me his stock speakers out of his 13' ultra. Might as well swap those with my used ones. These new ones have zero miles on them. Thanks for everyone's help. I have looked for about 3 hours for manual, but, it hasn't turned up yet. Hope I find it before the panama bike week in a couple of weeks.
Loc_Tite
08-29-2014 07:46 PM
