Plasti-Dip - Lets see what you got
04-09-2015, 12:49 PM
Quote:
Originally Posted by
SafetyMan
I start with 2 very light coats, and don't let fully dry. I like to lay the next while there is still some tack.
The third through 6th or 7th coat is laid on thicker.
I have been known to flash set with a hair dryer.... I can lay 6 coats in about 30 minutes, then let set at least overnight before dicking with it.
My fuel door is needing to be redone, the edge is loosening up for some reason, maybe I'll video the removal/redip process....
Thanks for all the tips. Video would be cool!
04-09-2015, 02:00 PM
Does the Plasti-dip have any problems with heat? Or would using it on heat shields or parts that get hot be fine?
04-09-2015, 02:36 PM
jledesma08
http://lmgtfy.com/?q=plasti+dip+heat
04-09-2015, 02:46 PM
Here's mine. Did the whole bike but this was after adding bags and rear filler
04-09-2015, 04:12 PM
jledesma08
I haven't done anything "hot"... nor will I.
I don't want to see what kind of mess it makes when it melts....
04-09-2015, 04:37 PM
SafetyMan
The manufacturer claims Plasti-Dip will hold up to 312 degrees.
04-09-2015, 04:42 PM
Pumba11
How hot do you reckon your heat shields and exhaust get?
I'll not try it.
04-09-2015, 04:43 PM
04-09-2015, 04:44 PM
SafetyMan
I'll not try it.
I wouldn't try that either.
04-09-2015, 05:17 PM
jledesma08
When the Plasti Dip gets hot it tends to turn into a stickier substance and is harder to peel off.. When i painted my heat shields I sanded them down, applied high temp primer, and then 4-5 coats of high temp paint
