Easy fix for front brake brake light actauter??
brake light actuator
Drill a small hole in the middle of the actuator and install a small sheet metal screw that's a quarter to three eights of an inch long.don't drill very far into actuator just enough to get some threads for the screw.done this plenty times and works fine.of course u have to remove the lever.you will have to adjust the screw to get the right amount of lever play to make brake light to work.easier for me to do it than describe how to do it.good luck.
woodster54
09-24-2012 08:50 PM
jumboshrimpster
03-30-2010 03:05 PM
