SE Heavy Breather with lowers?
Old 04-05-2015 | 01:04 PM
REPO1's Avatar
REPO1
Default SE Heavy Breather with lowers?
Does anyone with lowers run the SE heavy breather? If so could you post pictures? How much clearance is there?
Old 04-05-2015 | 01:08 PM
RushKing14's Avatar
RushKing14
Here is a link to the one for use with lowers. It is shorter than the standard length one. There should be plenty of clearance.
It is also a good deal from Kutter.
http://www.kutterharleyonline.com/ha...-kit-28716-10a
sanman4ever's Avatar
sanman4ever
The MOCO makes a compact version for use with lowers. P/N# 28716-10A
Old 04-05-2015 | 02:58 PM
skratch's Avatar
skratch
with the compact filter, you get about 3/16'' of clearance. the front of the filter does also interfere a little with the door opening. i have the magnetic doors, and the one on the right does not open all the way. it does open far enough though. it will not fit if you plan on using speakers in your lowers.
Old 04-05-2015 | 03:15 PM
REPO1's Avatar
REPO1
Thanks for the photo. Looks a bit tight for my liking. Guess I will go another route.
tdavidson99
03-20-2014 12:25 PM
booch
08-25-2013 09:03 AM
UltraNutZ
08-01-2013 04:44 PM
Sallyman
05-31-2012 12:36 PM
thistlethunder
09-21-2010 03:16 PM
Quick Reply: SE Heavy Breather with lowers?
