rough idle when hot
Old 04-02-2015, 06:22 PM
Bogart999's Avatar
Bogart999
Bogart999 is offline
6th Gear
Default rough idle when hot
I have an '11 Road King, mostly stock, and recently I'm noticing that the engine is running rough at idle when hot. This happens at a long traffic light, or, in stop and go traffic. This does not seem to happen when engine running at cooler temps, or, when the outside temp is cooler. It seems to run fine otherwise, and, I do not notice any roughness/engine missing while moving, or, at higher rpms.
HD techs don't have any ideas, just want to start throwing parts at it (coil, plug wires, plugs etc).
Anyone have a similar experience? I welcome any thoughts/ideas to correct this
Old 04-02-2015, 06:31 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
is your EITMS activating?
if so, it will only occur at idle with a road speed below 3 mph- pretty much under the conditions you describe
it is removing heat from the motor internals.
Mike
Old 04-02-2015, 06:32 PM
FinalShot's Avatar
FinalShot
FinalShot is offline
Do you have any type of tuner on it? If you do, remove it, go back to stock and start there. Make sure your air filter is clean and try a bottle of your favorite gas additive to see if it helps.
Also, do you have ETIMS activated and it's just that that is shutting off the rear cylinder as designed?
Old 04-02-2015, 06:33 PM
my67pnycar's Avatar
my67pnycar
my67pnycar is offline
Sure its not the Engine temp management system kickin on? That would explain what you describe, hope that helps.
EDIT: dayum, yall beat me to it, yall posted while I was typing my post, lmao..
dmkx3's Avatar
dmkx3
dmkx3 is offline
how many miles? have you changed the plugs recently?
Old 04-02-2015, 08:32 PM
Bogart999's Avatar
Bogart999
6th Gear
It could be the ETIMS, however, what would be the cause of excessive heat to cause this? I have not had this issue in the past, even during the hot south FL summers.
23k miles, Intake and exhaust are stock. Fluids changed in the last 30 days. New sparkplugs, two weeks ago, plug wires and coil check out - ok
Old 04-02-2015, 08:53 PM
J929626's Avatar
J929626
J929626 is offline
Maybe it has been disabled all this time and you inadvertently enabled it.
Old 04-03-2015, 06:03 AM
717rfulton's Avatar
717rfulton
717rfulton is offline
I wouldn't think it would be the ETIMS if you've had it to the dealer for this issue and they didn't suggest that. But you do know how to turn it on and off tho. Right? It's probably your intake and cylinders filling up with all the carbon/engine sludge from you breathers pumping into your air filter. The sensors get dirty and give false reading as well. Hows your fuel mileage?
Old 04-03-2015, 06:50 AM
vickers1's Avatar
vickers1
vickers1 is offline
Mine comes on all the time in the heat of the summer. Hot FL & GA summers is the cause of the excessive heat.
Old 04-03-2015, 08:58 AM
shooter5074's Avatar
shooter5074
shooter5074 is offline
Location: Western Illinois, land of bad roads, and corrupt politicians
Turn your ignition on and the run switch set to run. Roll your throttle forward, and hold it while looking at your cruise control light. If the light flashes green, ETMS is activated. To deactivate it, roll the throttle forward again until the cruise light flashes red. You can also do this with the bike running, if you need to activate/deactivate ETMS.
Quick Reply: rough idle when hot
