Possible?
Location: Western Illinois, land of bad roads, and corrupt politicians
To reset the code with a TSSM equipped bike (with button fob), you will:
1) Set your kill switch to off
2) Quickly turn the ignition switch on, off, on, off, on
3) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
4) Press and let go of your fob button twice (press fairly hard, it's designed to resist being pressed by keys and whatnot in your pocket)
5) Current PIN number will be displayed on odometer
6) Change the PIN by pressing the left signal until the desired number is reached
7) Press the fob button twice to cycle to the next number and repeat step 7
8) Press and let go the right signal and turn ignition off when 5 digit PIN is satisfactory
NOTE: Steps 2 through 4 must be completed in quick succession of each other.
My '03 has the push button fob. When new it came with 2 security cards, 1 tells you how to turn off without the FOB the other is the number for a dealer to research and get the original PIN. Both are the size of a Credit Card, and the 1 with the PIN is folded in 1/2 with a picture of the FOB on the outside.
