Best method to cut down a windshield?
I have a bat-wing fairing and my windshield is 11.75" high in the center. In the morning (when we are all a bit taller) I see over it, but most of the time the top is right in my line of sight. I would like to nip about 2" off it. What is the best way?
I'm 6'4".
I'm 6'4".
RE: Best method to cut down a windshield?
1. Using existing windshield make a cardboard template of the curvature.
2. Put masking tape on the windscreen about 3-4 inches wide where you want to make the cut.
3. Using the template made in 1. above draw curvature across the tape from step 2.
4. Cut above line made in step 3 with an electric saw.
5. Use a belt sander to smooth cut from step 4. to line made in step 3.
6. Remove excess tape.
7. Polish and enjoy
Or take it to a glass shop and let them do it.
7. Polish and enjoy
Here's an article submitted by Bill Nourse that will show you how https://www.hdforums.com/m_73850/tm.htm
I used a jigsaw with a hacksaw blade. It cut the windshield like a hot knife in butter. Didn't break out the belt sander, instead I hand sanded using 120 then 320 grit paper. Polished with 400 then 600 the 1000 grit wet/dry paper. Looks completely factory done. The cut edge is even slightly rounded due to the hand sanding (using a pad). I just happened to have the above sand papers on hand...
Received 7,729 Likes
Ken
My suggestion is buy a different windshield from these guys:
http://www.customflhtwindshields.net/index.htm
You can get better wind protection at a reasonable price. I sold my take off windshield on e-bay for $100 and this allowed to buy the height and style I wanted and have money left over just in case you decide to do some more stuff to your bike. I am 5' 10" and would rec. the 9" tall model. I got the dark tint flat top and it looks real sharp. The windshields they sell are top quality and look great. They have all heights.
I bought a new windshield on Ebay for 18 dollars brand new with the plastic protective paper still on. It looks great and I have the original for future use. I went with the slightly tinted.
Good luck.
[IMG]local://upfiles/494/F8B115310D2644F288B71058DEA99DA0.jpg[/IMG]
Good luck.
