tired speaker upgrade
rented a 2015 ultra at daytona, sounded awesome! that said i dont have the budget for a serious upgrade, was looking at picking up a set of take off 6.5" speakers off a 2014 and put the adapter rings in for my 2007, is the sound much better on the 6.5" than the 5.5" or is it not worth it?
If you want to do this audio upgrade right the first time go with biketronics amp and 7.1 speakers. It's expensive but you get what you pay for. A friend of mine did the hogtunes upgrade and it was not impressive. There are a lot of threads here stating the same thing. Biketronics also has a lifetime guarantee. When I did my biketronics upgrade I was 100% satisfied. If you just change speakers you won't be happy.
I'm thinking along the same lines as you Marc..
Want an upgrade above the stock POS speakers, but don't want to dump a crap load of cash.
Here's what I'm looking at.. Take a look at the Polk db651 speakers (Crutchfield is a good place to start). A lot of folks have had good results with these and they run about $75 for a pair. They can handle 6-60 watts RMS (180 watts peak power) @ 4ohms, so you could use them straight up with the HK (outputs 20wpc). However, a modest amp will give you some more punch. Something like the Alpine KTP-445U ($150) would complement these nicely. It pushes 45w x 4 and is bridgeable, so you could also run it at 90w x 2. Would not want to crank the up all the way at 90wpc or you may blow the voice coils.. Anyway, this will not be plug and play like the canned solutions, so you would have some work to do. If that does not intimidate you, it will be much easier on the wallet.... Good luck in your search!
However if you got an amp or receiver looking for say 8 ohm, you should not use a speaker rated at a lower impedance (6.2, 4, 2, etc..). Hope this helps!
