sealed bearing wheel on early bike(1999)
I understand that a newer sealed bearing wheel (at least up to 08) can be made to fit an older timkin style bike. A trusted local indy told me a special sealed bearing with 3/4 inch ID is available, but he wasn't 100% sure it would work. Has anyone done this? What else might I be up against? I want to install the newer wagon wheel style to replace the flat spoke wheels I have.
If you use the later type of wheel they will take 3/4", 1" or 25mm sealed bearings, however there is more to it than that! The bearing housing is larger than the tapered roller wheels, so your rotors and rear pulley will not swap over. When I swapped over on my 1990 bike I used a later swingarm and brake caliper as well.
