2004 flhrsi wind noise
Old 03-27-2015 | 08:31 PM
mikeyglide's Avatar
mikeyglide
Default 2004 flhrsi wind noise
Just got this bike ,'04 flhrsi Got a whistle when between about 40 and 60. It is air passing over something .Any clues ?
It's somewhere out front .
Not sure where from.
Any ideas to isolate things till I find it?
Old 03-28-2015 | 10:01 AM
bigheadted's Avatar
bigheadted
take a leaf blower to it and see what spot makes noise ?? I had a similar dealio to you and it turned out to be whistling from the headlight trim ring, I simply used a hung of tape backed foam weatherstrip behind the trim ring and it was gone.
Old 03-28-2015 | 11:12 AM
Lucky1359's Avatar
Lucky1359
Check all your mounting points up front (windshield, passing lamps, trim rings, nacelle) maybe something worked loose a bit. Nice bike BTW mine started out like that then I got a wrench in my hand!
Old 03-29-2015 | 08:18 PM
skully1200's Avatar
skully1200
I agree with bigheadted. Mine started out with a single head light. I added passing lights. Then I added trim rings, and it started to whistle. Stuck a little weatherstripping in them. It quieted the whistle enough for me to forget about it.
Old 03-30-2015 | 12:22 AM
Ragtop's Avatar
Ragtop
I sure hope you guys are right about the trim rings!
I've been having the same EXACT problem, and it's been driving me NUTS!!
I was surprised to see the chrome mini shield still on your custom when
I first read the post, because mine was fine, no noise at all until I removed
that shield! As soon as I took it off, it whistles between 44-55 or so.
I even tried the ashtray shield under the forks which helped some, maybe 20-30%
but could never get rid of the rest of it.
Now I have something new to try, thanks for posting!
Dazzauk
EVO
08-29-2016 09:17 AM
btharris24
02-17-2016 01:48 PM
skully1200
08-02-2011 02:13 PM
Scarz
04-08-2008 02:43 PM
TBone
02-18-2008 03:59 PM
Quick Reply: 2004 flhrsi wind noise
