How do you get the outer fairing back on a Road Glide???
Old 04-23-2007 | 10:35 PM
Road Glider's Avatar
Road Glider
Default RE: How do get the outer fairing back on a Road Glide
Yeah that tip really worked great!!!
FYI..make sure you take off the windshield first. I didn't on the first try and scratched the blacked out portion on the inside of the windshield on the inner fairing when trying to remount it.
Taking out the headlights makes the job easy!!!!
Thanks again Rollntiger!!!
Old 04-23-2007 | 11:20 PM
ROLLNTIGER's Avatar
ROLLNTIGER
Hey no problem! I am like that, once I dive in and make up my to do something I go full force. My wife thought I was crazy. When I made up my mind to have my inner fairing painted I went in the garage with my tools, a sharpie, some masking tape and some baggies. I taped off all the wiring harnesses with A-A, B-B and so on so I would know how they went back together. I then placed different screws, nuts bolts in baggies and wrote in detail where they came from! I did it by myself no manual and it was fun! LOL The scairy part was after I got it back from the body shop and had that fresh paint, I was worried about scratching it! If you just take your time you will see how things fit and I said there has got to be a better way to get this Dm fairing back on! So by taking the headlight assembly out of thefairing youjust look through the hole while you arematching the inner to the outer and you willsay to yourself, "Why in the hl didn't I do this earlier!!
Old 04-24-2007 | 03:12 AM
atexn4christ's Avatar
atexn4christ
I changed to the silverstar head lamps today. I took the headlight piece out and it went back together easy. The only problem I had was the left side blinker wire did not want to go in right. It looked as if the dealer shoved in and pinched the wire and it wanted to go back in like that again.
ALstew
01-16-2016 04:08 PM
Ultrasweet
08-15-2008 05:44 PM
BcDog
03-23-2008 03:08 PM
molsen
11-04-2007 10:25 AM
harley0711
08-09-2006 06:26 AM
Quick Reply: How do you get the outer fairing back on a Road Glide???
