It's happened before, but after turning the bike off, getting gas, and restarting the bike, the unit came back on. I haven't had the problem again. Today, it won't turn on at all.
Unfortunately, this is starting to happen occasionally since the latest update. I've had it happen twice. So far, if I turn it off for 5-10 minutes it will reset and start-up. I've also heard that pulling the main fuse will also reset the system.
Thank you for the tip. I've never updated it, so it has the stock firmware/software that it came with from day 1. Unless they updated it when they did the recall work.
I second removing the big main fuse under the right side cover for 60 seconds and then reinstall and turn the bike on. This should remove power for everything forcing a system reboot.
