intermittent no charge. '08 ultra
Picked up a new to me ultra last week.
Out riding today, put on about 50 miles, and stopped at a buddies house.
When I left, got going about 2 miles down the road and noticed the engine and battery lights are on. Looked at gauge and it was at like 11 volts.
So, I turned off the radio and spot lights, thinking I'd try to make it home, about 5 miles.
Shortly thereafter, it started charging again and was fine for the rest of ride home.
Turned lights and tunes back on. All is good.
Bike has 27,000 miles. Is there anything that is a common issue on these ?? (My other bike is '02 Dyna) so not used to all these electronics.
Going to check the obvious, battery connections and such.
Just looking for pointers on common issues.
Thanks, Jeff.
Thanks, Jeff.
Voltage Regulator. Been there done that. Seriously, I had the exact symptoms on my 07 a couple years ago. It's the VR. I changed the battery first, thinking my battery was over 5 years old. ...but nah.. it was the VR.
I like this one. http://www.jpcycles.com/product/383-632
.......... check the input/output plugs on the regulator/rectifier assy - good chance they're loose.
............... possibly the regulator/rectifier assy is getting a poor ground - ensure that it is bolted firmly to the frame. No ground? No charge.
............ to properly charge the battery the regulator/rectifier puts out about 14.5 vdc and that can be measured from the pos battery lead to ground (or across the battery) with the engine running @ 1500 rpm.
easy to diagnose using the tech board/ electrical sticky diagnostics.
rather than replacing good parts
( sometimes just the act of replacing parts cleans up a bad connection which kept the old part from functioning).
aside from the 2012(?) Vr recall, I have never had a VR fail.
1st make sure the battery and battery cables are good, with tight clean connections.
( your cables should have clean tight connections at both ends, check for corrosion such as white powder coming out of the ends of the cables, the insulation shouldn;t "roll" away from the cable in your fingers- it'll only do this is the cable is rotted ( see below)
then I would disconnect the stator and clean the connections, same for the VR and then start checking.
any problems you see at the dash voltmeter, confirm with a real voltmeter attached to the battery or your battery tender pigtail
mike
mike
Checked battery cables, clean and tight.
Checked grounds under the seat. Clean and tight.
Removed VR, connections are clean and tight. Added some die-electric and reinstalled.
I will do the same for the stator plug.
Weather got cold here, again. So I'll give it another try when warmer.
If it happens again, I'll replace regulator.
Well, dealership will replace, as I just bought it and thus was my first ride.
Thanks for the info.
Received 49,928 Likes
Transfer Case .... Maybe he's riding an International ???
