Any True Duals or Exhaust advice 4 88
Here is my dilemma. I've always thought you have 2 headers you have 2 separate exhausts. I don't know why, was never told, just something I thought made sense. Less bends and impedence means more unrestricted air means more power. so true duals Is what I should get. Right? I love the look of 2 pipes coming from my bagger,
So which ones? What can I be looking to spend for full system?
Also going to purchase hi flow air intake? Is there a best combination or just go with what I like looks wise, because with a kN they will all basically be the same.
There is a difference in sound between 'true duals' and the siamesed duals that are stock, and that are on many machines...to me, it's the sound that makes the difference here. I have read, and I have been told by guys who have gone to 'true duals', that they have lost a little bottom end initially, but when they had the engine remapped, it came back and then some. For an 88, you need all the torque you can get, so that's an important task to take care of.
Personally, I don't think there's a whole heck of a lotta difference in intake efficiency between the various ones out there, so I think you're right...the K&N is the thing that's gonna make a difference. My 88 has the SE intake, with the K&N upgrade and a round traditional air cleaner, works fine with the Rinehart 2 into 1 exhaust.
The stock exhaust on my 2006 FLHX is for all intents and purposes a 2 into 1 exhaust with the left side hung on for looks only. When I first got it, I was put off by the fact that the right side was very noticeably louder than the left. When you put your true duals on, they should be equal.
I think you're on the right track already...if you like the looks and sound, go for it... You're probably looking at a minimum of five to six hundred bucks for head pipes alone...shop around...and don't forget, not all head pipes that LOOK like true duals ARE true duals...that said, I'd personally prefer pipes that are siamesed, I prefer the performance and sound of them...but that's me!
Good luck, exhaust threads are VERY popular here, but your question is a bit different and intriguing...
Most exhaust systems are designed for optimal engine performance for general street operation. They minimize or eliminate reversion and enhance the intake process. Their design is very complex. Tru duals (no crossover flow) are most effective in cases where the engine usually runs at wide open throttle like a drag bike. Reversion there is not an issue. But, at lower rpm's, reversion can cause interference with fuel intake. Thus the loss of power and possible stumble. Some fix the problem by inserting a restriction in the header to break the reversion wave. It often works. However, adding the restriction then can mean less intake enhancement at high rpm's and loss of some hp. That might cancel out the benefits of the hi flow intake. Not trying to bad mouth tru duals or anything else. Just trying to say that the engine components have to work in harmony for good all around performance. So do the research. Consider the consequences. Then make your choices.
I suppose the "exhaust" question can be answered in many ways; and it can be exhausting... so to speak.
I liked the sound of TD pipes, I found my 2-1-2 Power duals with monster ovals... was close but did not sound quite like TD pipes.
I got a set of MGS TD pipes ran them for a year. I did notice a drop in torque in the 2K-to 3K range. I ride hilly and twisty roads and go through the mountain passes frequently. So, I am now running a V&H 2-1 pro pipe, and my torque is back.
The 2-1 sounds good, not the same at the TD pipes.
Just my own personal exhaust experience.
duals
I did not research pipes enough.
