Your Stage 1 A/C Experience
I went with the Big Sucker, round HD cover and Performance machine servo cover.
http://www.performancemachine.com/mo...rvo-cover.aspx
I read something about oil potentially leaking out into the AC in another thread - a possible by-product of a Stage 1 upgrade. But I've looked around DK's web site and see lots of products but no comments directly on that issue. What am I look for? Is it just the addition of a breather?
http://www.dkcustomproducts.com/Prem...DIS-BRT-TC.htm
(BTW, I just saw S&S is only $114 at Eastern Performance, too. Gotta like that!)
Ok, got it. But if I don't have that issue now, will it be likely that I cause it with an AC change? Is the oil blow a function of the AC, or is it the engine (and the AC is the just lucky recipient of the blow back)?
Yes the air cleaner is the place where your blow by is going. As said before look into the dk discreet breather or I've seen others construct there own systems. Also stated before try 3 1/2 quarts instead of 4 quarts of oil. I've noticed with 3 1/2 quarts that I see less oil on the air filter. Still some but not as much as if I were to run 4 quarts.
Received 75,992 Likes
