Lighting Issue
Lighting Issue
I have a 2014 Street Glide I bought the Custom Aux. lighting kit from HD got it all assembled. Wiring wise pretty simple take the new plug from the lighting assembly and simply plug it into the existing plug where the existing turn signals were plugged into then remove the dash and switch out a blank with the new switch that is provided with the kit and plug the factory plug into the new switch. Here is where the issue starts both turn signals work perfectly but when I press the button to turn the lights on only 1 light comes on. What I have tested is if I unplug 1 of the lights the other works then plug it in and unplug the other and it works I have also plug the left side into the right and the right into the left each light worked but as soon as both are plugged in and the button is pressed again only 1 light comes on. Any suggestions would be greatly appreciated.
Thanks,
Dan
Thanks,
Dan
Recently installed the exact same setup on my 14 sg, hd aux light brackets with daymaker lamps, didn't run into any issues and work great. Only thing I could think to check is maybe the 3 or 4 small wires that u have to individually insert into the small connector that clips into the stock lighting harness, to make sure the colors and polarity are correct. If I remember correctly, the small connector was a bit tricky figuring out which was top or bottom, left to right, and the diagram wasn't 100% clear? Sorry i couldn't be more help
Street_Glide_2012
Electrical/Lighting/Alarm
02-13-2013 01:05 AM
