Replacing front tire
Old 03-11-2015 | 09:30 PM
kryingame's Avatar
kryingame
Default Replacing front tire
Monday, I plan on replacing the rear tire on my 2012 SG.
On average, how many miles are you all getting on your front tire before replacing?
thanks
Old 03-11-2015 | 09:53 PM
goodbirds's Avatar
goodbirds
Lightbulb
I typically get around 20,000 on the front, and 12-15,000 on the rear. A lot depends on how you ride. I use gears for most deceleration coupled with light braking pressure (unless more is needed to avoid a problem) which seems to extend the life of the rear tire.
Bear in mind that 70% of the braking power comes from the front wheel since the forces of weight and deceleration bear down on the front tire. Run 38 psi. The rear tire bears the burden of acceleration so if you ride in a gentle manner, the tire will last you longer. While braking, the rear tire unloads quite a bit and may skid or slide if braking too hard resulting in extra wear and tear. Run 40 psi for maximum wear.
Some people will replace the tires when they get a bit "squared" off, so when you're leaning over, the tire tread contact is reduced and it will feel a bit loose or squirming. If that doesn't bother you, you'll get great tread life. If it does, expect 7-8,000 on a rear tire.
I hope my 50 years riding experience helps you.
Old 03-11-2015 | 09:55 PM
Tinman265's Avatar
Tinman265
The way these OEM tires wear I will be changing the front with the rear. It was cupped pretty bad...... Always had proper inflation.... Almost 18,000. Stock 17"/16" set up for a Limited
See how the 19"/18" CVO set up does......
Old 03-11-2015 | 10:56 PM
hd_rolling's Avatar
hd_rolling
I always just change both out at the same time, two fresh tires always ride better to me than just one. Front run's me $105 for an American elite 19", normally pay $35 to have my indy install it on the wheel. I remove front and rear myself that saves a bunch.
Old 03-12-2015 | 12:42 AM
kryingame's Avatar
kryingame
On my current set, I have about 12K on both. The front seems okay but the rear is a headache. I always put 40lbs in the both. After a good ride, the rear will drop down to the 20's but the front is always constant. Last time I rode, I felt a good wobble from the rear while on the Highway. I'm just wondering if I should bite the bullet and just replace both (even though the front seems to be fine). I don't want to have to come back to the dealer in a few months...
Old 03-12-2015 | 08:23 AM
hd_rolling's Avatar
hd_rolling
Have you checked to see if your dealer is running any sales? Its Daytona bike week, some of the dealers I've been to do a $1 install on two new tires around bike week times.
Old 03-12-2015 | 01:05 PM
Leftcoaster's Avatar
Leftcoaster
Two rear tires to one front tire....every time.
Old 03-12-2015 | 04:27 PM
kryingame's Avatar
kryingame
When I called, they said there's a 20% sale off of the tire and 20% off of installation. I don't think that's bad but I will see if there are any additional sales/promotions.
Thank you!
Old 03-12-2015 | 04:45 PM
White Ice's Avatar
White Ice
I change my tires at the same time. I got 40k out of the OEM set and 40k out of the American Elites. Trying the Commander II's this time.
Old 03-12-2015 | 06:00 PM
hd_rolling's Avatar
hd_rolling
Thank you!
They all do there own thing but just before or during bike weeks most do some type of promotion.
Quick Reply: Replacing front tire
