Cupped Rear Tire
Old 03-10-2015 | 05:00 AM
Beezr's Avatar
Beezr
Thanks for the all the advice guys. I used the dyna beads on my last bike (2007 Nomad) and they worked well although that bike was very hard on tires. It's just the nature of some bikes I guess. I had switched to Cobras and really liked them but they started cupping on the Nomad as well.
sweetlu , neither the 8mm or 10mm valve stems you showed the link to will work from what I see because the hole is about 11.5mm. Has anyone else changed to an angled valve stem and if so what size and where did you get them from?
Old 03-10-2015 | 12:31 PM
Big Limited's Avatar
Big Limited
My limited will be a yr old the 1st of april. I got 13,330 on it now. I keep 40 to 42 lbs of air in the rear and check them once a month or so. Checked the rear for cupping and had none. Checked tread depth with tire gauge and has 5/32 tread left. Might go quick from here on out but i would think 4 more thousand or so. Will see
Old 03-11-2015 | 01:16 PM
MNPGRider's Avatar
MNPGRider
Originally Posted by groupw
"Colored a distinctive, cheerful shade of orange"
.... a cheerful shade of Orange?
..... does it really balance as well as advertised ? does it annoy the guys that eventually change the tire ?
It works as advertised, or even better. I'm getting more than 15,000 on my rear tires, more than 25,000 on my front.
When your tech dismounts the tire, he will find all the Ride On across the inside of the tire in the tread area. If there is any on the wheel, it rinses off with plain water. Many posters here have even stated they will scrape it out of the old tire and put it in the new one. I've never done that, and don't intend to, as the directions are pretty specific on how many ounces to use based on tire size.
Ride On is a brand. Don't confuse it with other brands on the market, such as Slime or Fix a Flat, that give techs a lot to complain about.
Old 03-11-2015 | 07:47 PM
Beezr's Avatar
Beezr
I've reused dyna beads.
Old 03-11-2015 | 07:49 PM
Beezr's Avatar
Beezr
What kind of tires are you running?
Old 03-11-2015 | 08:11 PM
RushKing14's Avatar
RushKing14
Originally Posted by sweetlu
Beeze Beeze Beeze,
first.... rear gets higher pressure than front ... Stock Dunlops are 36 for the front, 40 for the rear.
Second .. buy the 83 degree valves so you can install them when you change tires
http://www.motorcycle-superstore.com...T.ac=SLIsearch
third ... take a look at the Metzlers, I’m biased towards the Avons, but heard great things about the Metzlers.
http://www.metzeler.com/site/us/prod...version=951929
Hope this helps
Those look great, but what size would one buy for a stock wheel on a '14 King? Anyone know? The page shows 8mm and 10mm
And to the OP's original thread theme, I am over 10K on my tires, and no cupping with plenty of tread to spare on the stock Dunlops. I run 38 front and 42 rear on mine.
Old 03-11-2015 | 08:16 PM
BonaWho?'s Avatar
BonaWho?
Tire wear can be weird from my experience, the below tire had correct pressures and monitored closely, especially after showing this wear. Bike was ridden as usual and very few loaded tours. The tire mounted before (Dunlop) and after this tire (Michelin) worn normally.
When this was first noticed everything was checked and rechecked, rebalanced and the rear end was also rechecked. The only thing I didn't do was unmount and remount.
Obviously near the end of its life the bike pulled severely and the wear was evenly all the way around on that side with the tread beginning to show at my mark.
This was an Avon Strom 2 Ultra mounted on a FJR. Avon was contacted about this but I never got a reply, emailed twice and called once.
I've notice cupping on many BMW front tires and my FJR would cup a bit with the early Pilot Road's of Michelin's but tire psi was very critical on this bike, low psi in the front and it would feel like a slug. 40psi in the front was common with this bike in order for it to feel normal.
Old 03-11-2015 | 08:37 PM
okcjetmech's Avatar
okcjetmech
You must be living right. I had to replace the rear on my 13 Limited (bought it Aug 12) with about 9K on it and it was trashed cupped really bad and cords showing. I put on a 2nd Generation American Elite back in Oct 13 and now at 26+K and it still has 7/32 in the center. Replaced my factory front at 15k cupped bad and balding with the
2nd Generation American Elite front and it has 3.5/32 left. I run 40psi rear and 38 front, no cupping on either one.........
Old 03-11-2015 | 08:41 PM
SSI Dog's Avatar
SSI Dog
Go to Kurveygirl.com. They have a pdf file with all HD wheels and what size valve stem it requires.
Old 03-11-2015 | 09:20 PM
RushKing14's Avatar
RushKing14
Thanks man. That PDF only lists the CVO Kings in the '14 although all of the ones for '13 show as the 11.3mm so I guess they might be the same, but not sure. I'll be at my stealer this weekend, and ask them to be sure.
Quick Reply: Cupped Rear Tire
