Finished DTT install guide....
Old 04-21-2007, 11:29 PM
PaOutlaw's Avatar
PaOutlaw
PaOutlaw is offline
Default RE: Finished DTT install guide....
Here's a question for you gearheads.............will this DDT system work on a '99 TC 95"? I've read a couple threads now...........talking about the o2 bungs etc. Don't believe My current exaust has or calls for those sensors/bungs.
Outlaw
Old 04-21-2007, 11:39 PM
SpikeCT's Avatar
SpikeCT
SpikeCT is offline
Im not sure about the 99 PhilM could answer that, but if an EFI. As for the bungs you need to have them welded on the pipes. The DTT comes with 2 bungs and you could take them to a local muffler shop and have them installed. Just need to select a location for them while your pipes are on and mark the area with a marker. Just make sure when welded you have hte bung pointed in the correction direction. Being round you can skew the bung and if not carefull could end up causing an interference.Make sure you can install them and get a wrench or 02 Sensor socket on it.
Old 04-21-2007, 11:47 PM
PaOutlaw's Avatar
PaOutlaw
PaOutlaw is offline
ORIGINAL: SpikeCT
Hopefully PhilM will chime in then. This is definately something I would be interested in if the application will fit my '99.
Outlaw
Old 04-21-2007, 11:51 PM
SpikeCT's Avatar
SpikeCT
SpikeCT is offline
TCFI II Fuel Injection Controller for 2001-2007 Twin-Cam with Delphi® System
Off of there website... Sorry!
Old 04-21-2007, 11:57 PM
PhilM's Avatar
PhilM
PhilM is offline
Actually, it will work. They sell a replacement harness that resolves the issue.
The 99~01 TC Touring bikes had an M&M ignition module and throttlebody. 02 & later use Delphi units.
As I mentioned, you can use the system on your '99. You just need to purchase the new harness, in addition to the DTT system itself. Now, having said that... I still think you'd find it more than worth while...
Old 04-22-2007, 12:04 AM
PaOutlaw's Avatar
PaOutlaw
PaOutlaw is offline
ORIGINAL: PhilM
So I can purchase the harness with the DDT unit (as in together)??
Outlaw
Old 04-22-2007, 12:22 AM
Harley Rulz's Avatar
Harley Rulz
Harley Rulz is offline
I DID IT!!!!!!!!!....With allot of help from John and Phil.These two guys are salt of the earth great Guys.Thanks allot You 2!!I gotta thank Shooter64 also for the awesome price (check with Shooter before You buy ANYTHING for Your bike).Don't think twice people,go get the DTT and get it put on Your scoot.It took Me about 6 to 8 hours with a few mishaps.This thing is so amazing that I can't put it into words.When I first rode it,the turn signels would not turn off automatically and the idol was going crazy (around 1400) and the DTT worked out those problems within 15 miles.
Dalton,
Don't worry Buddy.If I can install this then I know You can.Phil and John can walk You right through this with no problem.Hell I can even help a bit.It's VERY intimidating when You start but trust Me,it's a piece of cake.I think I could do one in 3 or 4 hours now.Just do it!!
Anyone want to buy a power commander?
Old 04-22-2007, 12:27 AM
PhilM's Avatar
PhilM
PhilM is offline
From: http://www.daytona-twintec.com/tech_tcfi.html
__________________________________________________ ____________________
A conversion harness that allows TCFI installation on Twin-Cam 88® engines with the Marelli fuel injection is available from Thayer Sales (585-762-4705). Please contact Thayer Sales for details.
[IMG]local://upfiles/8665/BA71A25F699F40C49BB25EE0581D2DD5.jpg[/IMG]
BelchFire
02-20-2020 03:35 PM
flyboyron
2014-2023 Touring Models
06-10-2017 10:21 PM
Ultra61
11-17-2007 05:13 PM
Quick Reply: Finished DTT install guide....
