Lessons learned while installing apes
I did mine on my 97 softail custom and only problem was the risers I bought hide the wiring through them. wasn`t happy with bar position and when I pushed them forward, cut my wires. damn, lesson learned. ( wires went through risers, didn`t come out in middle of bars, two holes in handlebars where risers were) if that explains it any better
I just put 12" twin peaks on my bike.....I was planning on getting 10" but people I talked to and reading online said "whatever bars you think you want, go 2" taller". So I did and no regrets what so ever. I would've been disappointed in the 10". It would have been a hell of a lot easier and cheaper with 10"s but the money and time was definitely worth going up a size!
Just my two cents for anyone upgrading bars.
Got my 12" Monkey Bars installed over the weekend. Went with a pre rigged kit from Hill Country (very happy with their product) to save myself some grief. Install wasn't too bad as it was my first time tearing my bike down this far. I did have a few minor hiccups - exhaust flange bolt almost stripped, forgot to screw to O2 sensors back in before re installing the exhaust.... Had to google a video on bleeding the brake as it didn't seem to be working, found out I just needed to take my time which was hard to do as it was the last step. Feel rather good about accomplishing the install with no physical help. Very happy with the results.
I do have a couple questions:
1. I only adjusted the clutch cable as per the manual, I did not adjust the actual clutch as this was done last fall as part of the 5k service - I don't need to have it readjusted do I?
2. I didn't see any pinch points or at the clutch or brake cables when turning full lock to lock but is there any other areas I should look for?
I did use the poly bushings on my install of Wild Ones 577 bars (12.5"). I only wish they were more ridged ( Good and Tite brand ). +6 on the clutch cable and brake line was perfect.
