stearing head grease??
ORIGINAL: electaRICK
ok wise-n-mighty forum,,, what grease have you guys been using on the steering stem???
I dont want the crap that gets hot and melts,drips,runs, on my Ultraclassic
got any tried and true brands/ methods ?
and how much would I pump in the zerk for my first filll?
thank you for your time
Rickster
Rickster
Typically, all is well until the first hot day when the "excess" grease will puke out - mostly from the bottom bearing. Another round with paper towels and Q-tips will clean it up the second time. After the second cleaning, some more will seep out, but not so much that it makes a mess.
Typically, before I wash my bike (which ain't that often), I clean up the steering bearing area, the wheels (with the bike on a bike-jack), and the underside of the engine and frame. Then I wash the bike.
By the way, I love having the grease fitting on the neck. I had to drill and tap the neck of my FXR to install the grease fittingbecause otherwise, it would require dis-assembling the whole front end of the bike to repack the bearings by hand. Good 'ol HD designed the FXD's so that the owner had to dis-assemble the front end to repack the steering bearings - as I remember, the FXD neck is designed differently than the FXR's and installing a grease fitting does not work.
JMHO
mi2az
07-02-2011 07:44 AM
harleybob
04-08-2006 12:58 AM
