Okay so now I am hot for the 12" KST mayhem bagger bars for my 2012 street glide thanks to my fellow forum members. But I am finding contradicting information regarding the cable and brake line lengths. I have read use a 6+ or even a 8+ clutch cable and I also read use a stock clutch cable with a reroute. Then I see where a 6+ brake line is recommended, but have read where the stock is also used with a reroute. I guess I am confused, can anyone straighten this out for me. Thank you for your time,
Bryan
Call eastern performance, tell them what bars you want and they will set you up with the rest. You get a discount for being a member as well. Don't forget new poly bushing.. I got everything I needed from them in one order and had it at my door 3 days later
I have 12 KST's. Extended the wires everything else is stock!
How is this possible? Even Eastern Performance recommended +6 for both? Did you have to reroute them? If so, where do you run the lines now. Thank you for your response.
The only way that is possible is if he has a 2014 or newer bike.
