Fairing mirrors
the fairing needs to be drilled- make sure you get the correct drill template ( or ask seller to make a template for you).
there is a reason these are often available used...you get to see your forearms pretty good.
for you current problem, try mirrors with different stalks- are your controls at a good angle on the bars?
mike
mike
Mike,
So even the fairing mounted mirrors present a blind spot (arm/forearm)?
Controls are standard set-up but come to think of it maybe I can rotate them upward so that the mirror mount is tilted up and away so that my arms don't show up in the reflection.
Thanks for the idea. I'll try that. I do still like how the fairing mounted mirrors clean up the handlebars.
Received 49,852 Likes
That's what another member also said. Sounds like no matter what mirror that's used, arms/forearms are still visible.
