dragos dragula 2 2 into 1 and 255 cams
I got nothing bad to say about Dragula (except too loud) and nothing good to say about 255s (ok in 96). But I'd guess ya would have more pipe than ya need or ought to have.
What baffle did your dragula have in it? I'm happy with the 255 so far in my 103, "not summer yet"
So we will see how it goes.
I don't mind loud pipes, I'm running cfrs right now.
I talked to frank at dragosbikeworks he said the dragula 2 would make a good bit more low to mid range power and more hp to. (With the 2.55 baffle)
Not exactly the same but... I had a 2-1 Fat Cat. Pulled it off because of the noise and installed a Fullsac CX pipe with his 2" cvo baffles in CVO cans. I've got almost the same Seat of the pants torque and HP as with the 2-1. With a lot less noise. Unless your wanting the 2-1 look. Pull the CFR's off and get different slipon's. Call Steve George at Fullsac and ask him which slipon's/cam combo will give you the results your looking for. The 255's maybe holding you back. Still an EPA compliant cam. I wish I could change mine.
I have the dragula 2/2.55 baffle with stock cams on a 2014 Road King. The dragula 2 is not as loud as the 1st generation dragula the muffler body is longer and the baffle is wrapped. To me the pipe has a nice low rumble at cruise, now @ wot it will get loud but that is expected with any exhaust.
I had the first gen Dragula 2-1 with a 2.5" baffle on my previous bike, which had a Kurykyn cam that was closely equivalent to the H-D 255. The bike ran well and sounded fantastic. As previously mentioned, when you crank on it, the Dragula will bark. At cruising speed, It indeed had a nice mellow rumble.
I have no doubt to expect any less quality from the newest version. When I change pipes, the Dragula 2 will be my choice...
ringer1969
2014-2023 Touring Models
05-06-2018 05:49 PM
