Can this be true ????
Old 04-24-2007 | 12:07 AM
05flhpi's Avatar
05flhpi
Default RE: Can this be true ????
I actually had this problem before. I fixed it by hooking my battery up backwards. Now, instead of a draw, my bike creates voltage just sitting there. Only 2 small problems now...bike has 5 new reverse gears and no forward, and I can't get the lights to shut off....ever.
  #52
Old 04-24-2007 | 06:31 AM
dog155's Avatar
dog155
Look out back of his house,tell us if his space ship is sitting on rubber pads.
  #53
Old 04-24-2007 | 10:28 AM
choochoo's Avatar
choochoo
Majority of the time only on an exterior wall.
Seems no matter how weather tight you make the exterior
walls, you can always feel a cold draft around the switch / plug in.
So the foam gasket is supposed to help reduce the flow of that
cold air into the house.
But do beware of the 'TRON GOD he'll get you when you ain't looking!
ORIGINAL: voodoodrug
Ive seen electricians put extra insulation on wall switches to conserve energy? looks like a plastic/foam templet that goes behind switch cover?
  #54
Old 04-24-2007 | 10:39 AM
choochoo's Avatar
choochoo
Are you referring to me about the battery above?
If so then you'd be calling me a liar and that ain't nice.
and the statement about the battery is true!
Bike is 01 flhtci, wrecked 1/11/02. Feb 02 took in the house
stripped and as time and monney (mostly money) would permit
rebuilt and customized it.
That battery sat just likeI said on the back porch until March of this year.
I brought it in, put voltmeter on it and it said 4.89 volts.
I was surprised I thought it would be totally dead.
It charged up good enough to test starting the bike.
With charger turned to boost, it cranked over. Moved bike out of frontroom
(was there for 5 years ..no garage).
Put charger back on and bike started.
re-started bike 2 days later with out the charger.
Bike has sat outside now a month no charger soon as weather clears we will
see what happens.
ORIGINAL: BiggestDawg
I gotta brige for ya if you buy that one
  #55
Old 04-24-2007 | 12:57 PM
eglidebob's Avatar
eglidebob
ShouldI use synthetic rubber pads, or dino rubber pads? Amsoil, Redline, Mobil1, or oh-fishal HD pads? Will the rubber pad void my warranty?
  #56
Old 04-24-2007 | 02:10 PM
madurodave's Avatar
madurodave
ORIGINAL: em2780
ORIGINAL: garcon
A neighbor came over to look at my RoadKing and said I should put a piece of rubber under the stand when it is parked in the garage.He said that the jiffy stand will slowly drain the battery acting as a ground. Sounds kind of strange to me, but ?????
I was told that same thing when I picked up my RoadKing that is why I changed my jiffy stand from the metal one to a wooden one. If this is not truethen should I change it back.
I actually used a toothpick on mine as a stand. I heard the wood has to come to a point or it will conduct electricity.
  #57
Old 04-24-2007 | 02:12 PM
old95's Avatar
old95
& the beat goes go...................
  #58
Old 04-24-2007 | 06:51 PM
geargrinder's Avatar
geargrinder
I modified my jiffy stand so it's on upside down so it charges my battery when parked.
  #59
Old 04-24-2007 | 10:25 PM
Blue eyes 56's Avatar
Blue eyes 56
Funniest post Ive read yet! You guy's crack me up .Thanks I needed a good laugh! Has your neighbor asked for a metric cresent wrench yet?
  #60
Old 04-26-2007 | 01:39 AM
choochoo's Avatar
choochoo
ORIGINAL: Blue eyes 56
Actually I have a couple of these left over from the Reagan Years.
also got a left handed monkey wrench from my grandpa, but haven't found any monkeys left handed or otherwise that knows how to use it!
Quick Reply: Can this be true ????
