Water coming from exhaust.
My 2010 flhtk has always had water coming from the mufflers, not just when I startup but continuously as I ride. We have ridden all day through desert like country and it will still have water coming out after 500klms of riding. My dealer told me it doesn't happen so he is no help. Has anyone else experienced this?
The exhaust is stock standard as is the rest of the bike.
Thanks
Phil.
Thanks
Phil.
The process of an internal combustion engine will produce some water, but the exhaust system is usually hot enough to burn it off before you ever see it.
There is absolutely no water in your engine (air cooled vs water cooled), so it has to be coming from the combustion process.
You usually only see this in cold climates though (water vapor from exhaust in winter).
this may be seen partly as a result of your active exhaust system which we don;t have it the USA.
could be the side which is "off" is making water
odd that it would be seen in a desert ( dry) environment or when the motor is completely warmed.
Mike
Mike
I'm on the mobile site. Didn't realise you're from Australia. Good catch mkguitar. I was also unaware of the active exhaust system. The later Buells had an active exhaust system, even here in the States. I know when my bike had the stock exhaust it ran so hot there's no way condensation would have stood a chance in there.
Really ?? I have a real problem because my non cat equipped vehicles have water coming from the pipes too !!! Oh SNAP !! I have to run my bike to my "indy" and have him check my bike out. Thanks for the great info !!!
