Water coming from exhaust.
Old 02-22-2015, 06:53 PM
TSheff's Avatar
TSheff
TSheff is offline
Received 3,416 Likes on 1,584 Posts
Originally Posted by Buelligan666
I'm glad to see the guys from the "don't forget to change your air in your tires to spring air” thread could show up here to bust my *****.
Hope you change the air soon - it's warming up.
If you ride without a shield you'll notice when you come up on vehicles occasionally you'll feel drops. Normal to internal combustion with proper Fuel/Air mixture - if it ignites, I'd say your running a little rich.
Old 02-22-2015, 07:10 PM
Buelligan666's Avatar
Buelligan666
Buelligan666 is offline
FIRE!!! FIIIRRRREEEE!!!! HEH!! HEH!! FIRE!!!?
Old 02-22-2015, 07:50 PM
texaswiz's Avatar
texaswiz
texaswiz is offline
Originally Posted by Phil54
My 2010 flhtk has always had water coming from the mufflers, not just when I startup but continuously as I ride. We have ridden all day through desert like country and it will still have water coming out after 500klms of riding. My dealer told me it doesn't happen so he is no help. Has anyone else experienced this?
The exhaust is stock standard as is the rest of the bike.
Thanks
Phil.
After 500 klms you still have water coming from the mufflers? That is a little hard to buy into. You are not having a bit of fun with a us, are you? Post a picture, if you can.
Old 02-22-2015, 10:40 PM
TSheff's Avatar
TSheff
TSheff is offline
Thanks
Phil.
Just realized your location. I can't be sure how anything works there. I know I'd be scared of those 6' tall rats you have bouncing around.
Old 02-22-2015, 11:35 PM
Phil54's Avatar
Phil54
Phil54 is offline
6th Gear
6' rats are nothing to worry about its the wild goats and 6' tall birds you have to watch out for
Old 02-22-2015, 11:50 PM
Phil54's Avatar
Phil54
Phil54 is offline
6th Gear
Emu just to right of pole.
Old 02-23-2015, 07:10 AM
Phil54's Avatar
Phil54
Phil54 is offline
6th Gear
Hydrogen is in the atmosphere so yes you are onto something there. Best keep it a secret though. Keep working on it you will work it out someday.
Old 02-23-2015, 09:44 AM
Nute's Avatar
Nute
Nute is offline
If you're serious about your situation, I'd hesitate using your dealership for anything technical. The by-products of combustion of Fossil Fuels is CO2 and H2O. Usually the gases are hot enough to cause the water to be in vapor form, so you don't see it. If the exhaust gases are cool, the water vapor condenses and becomes visible in the form of water.
Old 02-23-2015, 10:05 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Wink
I'm on the mobile site. Didn't realise you're from Australia. Good catch mkguitar. I was also unaware of the active exhaust system. The later Buells had an active exhaust system, even here in the States. I know when my bike had the stock exhaust it ran so hot there's no way condensation would have stood a chance in there.
I believe the active Buell system was used on the 1200s only, from their launch. My Firebolt had it from new, although it was also disabled by the dealer. As for the big twins, like the OPs, the International models suffered from the active valve for a few years. Frankly I would remove it and adjust the tune to improve running - I used a Dobeck on my Buell.
Old 02-23-2015, 11:09 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
I'd like to try one of these hooked up "backwards"...so it acts as a 2/1 at low rpms and opens up at 3300 rpms or something like that.
maybe on one of my trips to Oz I will find a shop that has one in a junk box
mike
Quick Reply: Water coming from exhaust.
