FLHX TriBar LED light out
I had the bike running and noticed the LED light on the bottom of the rear fenderwas out. I pulled the seat to see if the plug had become seperated, all is good there. BUT, no light still.
I wouldnt think this thing could have burnt out already. Is there anywhere else I can check? A fuse or something.
Thanks guys.
Thanks guys.
RE: FLHX TriBar LED light out
Mine burned out too. It turns out the gasket between the lens and the light housing was not installed correctly at the factory and allowed water to seep in shorting out the led circuit board. My dealer replaced it under warranty. I did the labor and sealed it with a small bead of silicone around the mating surfaces and where the wires go in before I installed the new one. This makes it watertight and I'm not expecting any furthur problems like I had before.
BTW....Harley just introduced a running light/brake light combo as an upgrade for the running light only. Keep that in mind when you get it replaced under warranty.
