What brake fluid
I can see a couple of reasons for going with DOT5: The boiling point is higher (than DOT4), and it is not harmful to painted surfaces (so it says).
The question I have is if the bikes were using DOT5 pre-05, why did they change to DOT4 ? ( The 07's do not have ABS).
My thoughts were more about mixing of components designed for different types of fluids. Brembo calipers designed for DOT 4 while the master cyls. caps specify DOT 5? Are the materials used to make the components the same? Hoses, seals, o-rings? Is the ABS motor possibly churning air up in the fluid the only reason DOT 4 is specified in the later models? I understand the benefits of DOT 5, just wondering the compatibility of everything involved.
