new oil air shocks
I'm a lazy *** so what I do is I take the shocks off, mount one upside down and lean on the back of the seat pushing down and squeeze all the old oil out. do the same with the other shock. Then mount both and replace the oil either with a syringe or tube and funnel. Its not rocket science but I've also had trouble hitting the toilet after too many baileys creme and coffee, so talk him through it again.
I have changed oil in HD air shocks many times using a turkey injector syringe with the tip of the needle broken off to open the hole up a lil. It is still a lil bit of a slow process but it has never failed to work. I stick the tip of the needle in the rubber line attached to the air shock. It fits perfect & makes a good seal.
I found an easy way to get the oil out is to remove both shocks & connect all the hoses up on the work bench. Pump the shocks up to 25 or 30 psi with your hand pump. Clamp the shock you are wanting to empty upside down in a vise. Clamp off the hose going to the opposite shock. Remove the hose of the shock in the vise at the first connection, leaving a length of hose on the shock. Stick the hose in a graduated container so you can measure the oil as it comes out of the shock. It will be under pressure but it will not make a mess because the opening in the oil line is so small. Re install new oil as I posted above.
Mity Vac brake bleeder in pump mode will do it in about 5 minutes. Also works well for pulling the oil out.
BTW, I changed to 10w Bel-Ray suspension fluid. Made a big difference. Much better ride now with less air pressure.
2010 Limited with some stuff!!
