Notices
new oil air shocks
Old 02-13-2015, 07:52 AM
jbrelr21's Avatar
jbrelr21
jbrelr21 is offline
Originally Posted by hog95023
Where did the oil leak out of? Hopefully the air line hole. If it leaked from another location the shock probably isn't usable.
A vacuum as suggested works great. I've done several sets.
it came out during shipping from another member did a swap long for short.
Old 02-13-2015, 12:28 PM
60wt's Avatar
60wt
60wt is offline
maybe this will help
Attached Thumbnails new oil air shocks-shock-drain.jpg   new oil air shocks-shock-fill.jpg
Old 02-14-2015, 03:12 PM
X Iron Butt's Avatar
X Iron Butt
X Iron Butt is offline
Jealous of that old drill press. They don't make em like that any more. Mines old but it is a bench model so no screw table adjuster.
Old 02-14-2015, 06:35 PM
smithbrl's Avatar
smithbrl
smithbrl is offline
I'm luck enough to have a mill/drill and was able to change the oil like 60wt did it. Works fine.
Old 02-14-2015, 09:16 PM
Bagger_Vance's Avatar
Bagger_Vance
Bagger_Vance is offline
Originally Posted by Bmusg
Mity Vac brake bleeder in pump mode will do it in about 5 minutes. Also works well for pulling the oil out.
This. If you have a Harbor Freight close this is what I used and worked like a champ:
http://www.harborfreight.com/brake-b...kit-69328.html
Turn the shocks upside down in your vice when extracting and right side up when filling. I had the connectors from a compressor kit to hook everything up. I just installed air ride on my bike but can't test it out yet because of the snow.
Bill03E
06-30-2016 05:33 PM
DavidStiebel
09-20-2014 12:36 PM
1flhtk4me
04-06-2014 03:47 PM
scottdoege
02-08-2012 06:56 PM
terrysillik
05-29-2011 08:55 PM
Quick Reply: new oil air shocks
