PCIII On The Way
PCIII On The Way
Well I finally decided to go with the PCIII from Jamie at FuelMoto. I was nervous about getting this product but now I am anxious. Hope the increase is noticable. I have the A-Ness big sucker, Khrome Werks Slip-Ons, and I will be Installing the PCIII this Weekend. Any words of advice would be great.
[IMG]local://upfiles/25218/30028478373745A885B46991F1428945.jpg[/IMG]
RE: PCIII On The Way
ORIGINAL: JBELCHER7876
The canned map from Fuel Moto worked fine on my bike, and I have no issues with it. The gas mileage is, uh, anywhere from mediocre to good, and performance excellent, with no detonation, surging, excessive heat, or flat spots--even after I tweaked the cruise range for gas mileage. The "slow start-up" issue is a misnomer, with starting quick but not quite as quick when I don't wait for the "check engine" light to go off. Hestitation is rare and innocuous, only audible when blipping the throttle quickly in neutral, maybe once every 10-20 times.
Jamies maps are way better than maps from PC, his are true dynoed results from many hours of testing. It is plug and play but its best to hook up your laptop and set the throttle. This is simple and is explained in the cd that comes with the pcIII. You will notice a major difference and from many on here that have used fuelmotos maps and then dynoed the added benefit is small.
ORIGINAL: gunrunner
Just did my install last weekend on a 2000 Ultra. It took me 2 hours counting removing the bags and side covers. I had a heck of a time getting the cable though the frame in front of the battery box. I finally took the screws out of the battery box altogether and disconnected the cruise control module and cable. Went through easy after that. Be careful with the rubber boot you take off one cable and put on the PCIII cable. I thought it would tear, but slow and easy made it work. Haven't ridden it yet cause of the storms we've had on the East Coast. Maybe tomorrow!! Good Luck.
Thanks for the advice everyone, it sounds like I need to find a laptop to 0 the throttle. I am sure once I have the Info I will have no problem. I am also thinking about putting the unit in a bag to make sure water isn't an issue. Jon
