Battery tender on covered motorcycle?
I keep my bike in the attached, unheated garage during the winter on a battery tender. The cats have decided they want to use it as an activity center when they're in the garage and were scratching the saddlebag lids. I cleaned it all up and put a cheap Walmart cover on it to keep them off of the paint this past weekend.
Then I wondered if having the battery in the bike on the tender with the cover on it would cause any issue with gasses building up under the cover and cause any paint damage. I know the battery is gel-filled, not like the old acid batteries. Anyone know if this could cause me a problem?
It would suck to pull the cover off on a nice weekend and see the paint trashed.
Thanks!
Thanks!
Thanks!
Thanks!
Regarding cats and other things getting up underneath you may want to "search" for that because I believe others have talked about it before and how to stop critters from sneaking up there that are unwanted and into your pipes.
BuzzCap7
charging batteries release hydrogen gas.
under certain conditions reacting with water - hydrochloric acid
under other certain conditions ending up as cover art for Led Zeppelin.
a breathable cover is good.
for longer periods, remove the battery and keep in a warmer place like your basement.
"gel batteries" have vents and acid in them
I use mothballs in my sheds to keep the critters at bay. 99¢ store
mike
mike
Thanks
The tender puts only a little bit of charge in the battery, just enough to keep it going, not throwing a charge on it like a regular battery charger. And there won't be any gases to worry about anyway. Ever see a battery in a boat? Sealed in a plastic box so gases should not be an issue.
